workaround DNSError when running teuthology-suite
loic
Note: this is only useful for people with access to the Ceph lab.
When running a Ceph integration tests using teuthology, it may fail because of a DNS resolution problem with:
$ ./virtualenv/bin/teuthology-suite --base ~/software/ceph/ceph-qa-suite \ --suite upgrade/firefly-x \ --ceph wip-8475 --machine-type plana \ --email loic@dachary.org --dry-run 2014-06-27 INFO:urllib3.connectionpool:Starting new HTTP connection (1): ... requests.exceptions.ConnectionError: HTTPConnectionPool(host='gitbuilder.ceph.com', port=80): Max retries exceeded with url: /kernel-rpm-centos6-x86_64-basic/ref/testing/sha1 (Caused by : [Errno 3] name does not exist)
It may be caused by DNS propagation problems and pointing to the ceph.com may work better. If running bind, adding the following in /etc/bind/named.conf.local will forward all ceph.com related DNS queries to the primary server (NS1.DREAMHOST.COM i.e. 66.33.206.206), assuming /etc/resolv.conf is set to use the local DNS server first:
zone "ceph.com."{ type forward ; forward only ; forwarders { 66.33.206.206; } ; }; zone "ipmi.sepia.ceph.com" { type forward; forward only; forwarders { 10.214.128.4; 10.214.128.5; }; }; zone "front.sepia.ceph.com" { type forward; forward only; forwarders { 10.214.128.4; 10.214.128.5; }; };
The front.sepia.ceph.com zone will resolve machine names allocated by teuthology-lock and used as targets such as:
targets: ubuntu@saya001.front.sepia.ceph.com: ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABA ... 8r6pYSxH5b
